wolfie111
Aug 02, 2017Guide
Getting Errors: X Service Unavailable; Cannot Attach Device. Try Again LAter
In an earlier post from KayZak, 2016-11-15, now closed, titled "Getting Errors: X Service Unavailable; Cannot Attach Device. Try Again LAter", a solution was given to a problem that I'm having as well, since I've owned my ReadyNAS. Not sure how to reference that thread, but a solution was given that requires modifying code via SSH, of which I'm not familiar.
In brief, my problem is on the cloud tab of the ReadyNAS Admin page, Service Unavailable with red X, Internet Available green check, signed into ReadyCloud. That leads to other problems including inviting and managing users.
The solution from the user Deniro led to moderator mdgm making contact with the OP and fixing the problem via remote SSH. Is it possible to have someone help me here?
Thanks in Advance,
Wolfie111
Just had a look at your system. It should now be fixed.
- Thank you for referencing the link Stephen. I saw that, but I need some help with SSH, or someone who can look or show me how to check and modify the configuration files, via remote access perhaps? Suggestions?
- Thank you, solved.
I'll open a new thread for open issues.
