Björn_Eberhardt
Nov 30, 2016Aspirant
How do I change my ReadyCloud Admin?
My bad was to choose an invalid ReadyCLOUD admin Email address years ago that contained a "+" symbol on the left side. Somehow, with the new MyNETGEAR account logic, the server has a few issues with ...
- Dec 01, 2016
Hello Björn_Eberhardt,
Yes you are on the right track. Disabling the ReadyCloud is fine as it will not remove the current ReadyCloud users. Clicking Leave button on the other hand, means you are removing the ReadyCloud user that has admin rights for ReadyCloud access and will definitely also remove the current invited ReadyCloud users as well as their home/personal shares.
Should you want to change the ReadyCloud account that has admin rights, make sure you back up all the users' home shares first.
FramerV
Dec 04, 2016NETGEAR Employee Retired
Hi Björn_Eberhardt,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
