Trik1
Aug 26, 2015Aspirant
How do I change my ReadyCloud Admin?
I have a ReadyNAS 314, with ReadyCloud turned on. I want to maintain all settings but grant another user "administrator" privledges, as the employee that setup the ReadyCloud will be leaving the comp...
Trik1
Aug 30, 2015Aspirant
Ok, then how do I swap out the Admin, I am fine with only one user being the admin, are you saying once you associate a ReadyNAS with the cloud, whomever the user is that did that, forever is the administrator? It can never be changed?
BrianL2
Sep 08, 2015NETGEAR Employee Retired
Hi Trik1,
Yes that's right. You can swap or change the admin but toggling off the button under the cloud tab on the Admin page.
Just let me know if you have other questions.
Kind regards,
BrianL
NETGEAR Community
