kisa72's avatar
kisa72
Guide
Nov 24, 2019
How to see progress of ReadyNAS OS 6: Sync with Amazon S3
Hi,
Thanks for taking the time to read my question.
I've successfully connected my Readynas 104 to my AWS S3 storage as explained in the Netgear forum - ReadyNAS OS 6: Sync with Amazon S3.
What I can't see or keep track of is how the sync is going between my Readynas box and the S3 storage.
Is there any way to see the progress and success of the sync between the two locations?
Thanks,
Markus
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    kisa72
    Welcome to the Community!
    There should be logs under the Job settings when you open the options on the Cloud service or by downloading the full logs on the ReadyNAS. But real time monitoring of the sync in progress is not available on the NAS. Haven't been able to use this Cloud service though, not sure if there's sync monitoring on the S3 side.
    This might be a good Idea to suggest under the ReadyNAS Ideas Exchange board.
    HTH
    Regards
    • kisa72's avatar
      kisa72
      Guide
      Thanks for the reply Marc_V.
      I'm unable to find a log option under Settings at all. Any thought as to where else it may be?
      I'll also forward the idea onto the Ideas Exchange Board as you suggested.
      • StephenB's avatar
        Download the full log zip file from system->logs.  You'll find a log called amazon_s3.log in there.  Though there could well be relevant informatoin in the other logs too.
ProSupport for Business
