FloodlightMedia
Jul 10, 2016Aspirant
How to set ReadyCloud to Read-Only
So ReadyCloud is very convenient, especially for me to conduct maintenance remotely, but there is zero reason for it to be possible to delete files on our NAS remotely. I'm rather terrified that some...
- Jul 29, 2016
Ok. Not quite what I was after as it seems to only relate to invited users, rather than the main ReadyCloud account that administers those permissions. Still, I've found that taking the backup NAS offline and administering it through a remote connection to a computer on that LAN is an acceptable workaround.
BrianL2
Jul 13, 2016NETGEAR Employee Retired
Hi FloodlightMedia,
Kindly check this NETGEAR article and let me know if this suffices.
Kind regards,
BrianL
NETGEAR Community Team
- FloodlightMediaJul 20, 2016Aspirant
Is that link correct? Why would I need to log in to another system to view a knowledge base article?
I'm guessing you probably meant to link to this one: http://kb.netgear.com/app/answers/detail/a_id/23790/~/how-do-i-set-the-readycloud-access-rights-for-a-shared-folder-on-my-readynas-os?cid=wmt_netgear_organic
But it appears to be quite outdated (almost none of the menu links or options seem to exist anymore), and only takes me as far as I was already at anyway, which is changing users between read-only and read/write. The problem is that I can't do that with the main ReadyCloud (MyNetgear) account, as read-only is permanently greyed out (presumably because it has admin level features built into it that can't be turned off).
If my suspicions are correct, my only solution to is to remove the backup NAS from ReadyCloud, which is a bit of a pain from a maintenance perspective, but probably not unreasonable.
- BrianL2Jul 29, 2016NETGEAR Employee Retired
Hi FloodlightMedia,
I apologize for the wrong link posted on my previous post. Anyways, I've already updated it and hopefully that helps.
Kind regards,
BrianL
NETGEAR Community Team- FloodlightMediaJul 29, 2016Aspirant
