FloodlightMedia
Jul 10, 2016Aspirant
How to set ReadyCloud to Read-Only
So ReadyCloud is very convenient, especially for me to conduct maintenance remotely, but there is zero reason for it to be possible to delete files on our NAS remotely. I'm rather terrified that some...
- Jul 29, 2016
Ok. Not quite what I was after as it seems to only relate to invited users, rather than the main ReadyCloud account that administers those permissions. Still, I've found that taking the backup NAS offline and administering it through a remote connection to a computer on that LAN is an acceptable workaround.
BrianL2
Jul 29, 2016NETGEAR Employee Retired
Hi FloodlightMedia,
I apologize for the wrong link posted on my previous post. Anyways, I've already updated it and hopefully that helps.
Kind regards,
BrianL
NETGEAR Community Team
FloodlightMedia
Jul 29, 2016Aspirant
- BrianL2Jul 29, 2016NETGEAR Employee Retired
Hi FloodlightMedia,
It's fine. As long as you're okay with your workaround, I'm good with that too.
Kind regards,BrianL
