Gruncle1
Dec 19, 2016Guide
Internet Usage
So the questionis how much internet usage occurs when I am communicating with the NAS device. If I am on local does it just go to the router and back And if I am on readyCloud what happens This...
- Dec 21, 2016
FramerV wrote:
Username: admin
Password: password (OS6 units) or netgear1 (Legacy units).
The NV+ v2 (OS5) default password is also password. Some very old legacy units use infrant1
But if you use ReadyCloud you must have an OS6 unit.
An OS reinstall won't hurt the data, and will reset the admin password to password and the network connection to DHCP (get IP address automatically). It will require a reboot. The best instructions are in the hardware manual for your NAS model. Don't do a factory default, as that will destroy your data.
FWIW, if you forget the NAS password you could write it down and tape it inside the door of the NAS. Though security experts here will cringe, the truth is that anyone with physical access to the NAS can reset the password with OS reinstall procedure mentioned above. So there isn't much additional risk.
FramerV
Dec 21, 2016NETGEAR Employee Retired
Hi Gruncle1,
You could try using the default ones.
Username: admin
Dec 21, 2016Guru - Experienced User
FramerV wrote:
Username: admin
- Gruncle1Dec 21, 2016Guide
Thank you. I'll do the reset. It seemed kinda unclear in the manual, but I'll read it again.
- StephenBDec 21, 2016Guru - Experienced User
The key word is Reinstall. That's what you want to do.
You really don't want to do a factory default (which might be called a reset in some places).
- Gruncle1Dec 22, 2016Guide
After carefuly reading the manual, I crossed my fingers and toes and did it. Got back in with all data intact.
Thank you.
