beowoulf
May 18, 2016Aspirant
ios and ready cloud
Just did ios software update for ready cloud and app does not work. It immediately closes when opened and if you go to running apps and open it again it will close completely. This happens on new and ...
- May 30, 2016
New software update in App Store available. Bug fixed, works great now. Thank you Netgear.
beowoulf
Using ios 9.3.1. Have 4.9 gb free. No idea of ready cloud app version does not say in app center and won't load to see. Just downloaded today
BrianL2
May 19, 2016NETGEAR Employee Retired
Hi beowulf,
Mine works too (RN314 on 6.5.0, iPhone 6 running 9.3.1 and ReadyCLOUD app version 1.2.7 (126). You should see the version of the app under the 'Settings' tab.
Kind regards,
BrianL
NETGEAR Community Team
- beowoulfMay 19, 2016Aspirant
No version number shows under settings. New development, icon for app shows 30 in lower corner. This occurs on 2 different iPads on or off network and iPhone. Android app update went flawless. All Apple products have plenty of free memory and have latest iOS.
Update, the app worked but is quirky. Reinstalled from computer link to iPad through ITunes. App still shuts off on first load. Have to bring up running apps to get to it. The 30 number was actually the number of photos it wanted to upload to hard drive. Of course since they were there already from old software and login I now have doubles. Not sure what changed but did use different wifi network on router but that should not have caused app crash. Will keep trying on other 2 iOS devices.
- BrianL2May 19, 2016NETGEAR Employee Retired
Hi beowulf,
Thanks for posting updates. We may have to check or try this on our end and see if we'll get the same behavior. Most users of the latest ReadyCLOUD iOS and desktop app aren't having problems.
Kind regards,
BrianL
