beowoulf
May 18, 2016Aspirant
ios and ready cloud
Just did ios software update for ready cloud and app does not work. It immediately closes when opened and if you go to running apps and open it again it will close completely. This happens on new and ...
- May 30, 2016
New software update in App Store available. Bug fixed, works great now. Thank you Netgear.
BrianL2
May 19, 2016NETGEAR Employee Retired
Hi beowulf,
Mine works too (RN314 on 6.5.0, iPhone 6 running 9.3.1 and ReadyCLOUD app version 1.2.7 (126). You should see the version of the app under the 'Settings' tab.
Kind regards,
BrianL
NETGEAR Community Team
beowoulf
May 19, 2016Aspirant
No version number shows under settings. New development, icon for app shows 30 in lower corner. This occurs on 2 different iPads on or off network and iPhone. Android app update went flawless. All Apple products have plenty of free memory and have latest iOS.
