beowoulf
May 18, 2016Aspirant
ios and ready cloud
Just did ios software update for ready cloud and app does not work. It immediately closes when opened and if you go to running apps and open it again it will close completely. This happens on new and ...
- May 30, 2016
New software update in App Store available. Bug fixed, works great now. Thank you Netgear.
beowoulf
May 28, 2016Aspirant
Hopefully they recognize issue soon and find bug. Seems it worked on their ios devices. Not sure what else may cause conflicts as per other apps or installs however I have tried running it by itself off a fresh reboot and still get the varied results both myself and cacon describe. It's a shame, was nice app before it was updated to work with new login schemr. I would surmise that there are many more with the same issue out there who have not spoken out, I generally am one of those quiet ones but loved the previous functionality of Ready Clout, that is one main reason I purchased a high end Netgear router.
beowoulf
May 30, 2016Aspirant
