beowoulf
May 18, 2016Aspirant
ios and ready cloud
Just did ios software update for ready cloud and app does not work. It immediately closes when opened and if you go to running apps and open it again it will close completely. This happens on new and ...
- May 30, 2016
New software update in App Store available. Bug fixed, works great now. Thank you Netgear.
LaTower
May 30, 2016Aspirant
Now works :) Thanks.
BrianL2
May 30, 2016NETGEAR Employee Retired
Hi frisoco,
Can you update the ReadyCLOUD mobile app on your iOS devices (version 1.5.8) and see if you'll be able to access your ReadyNAS files?
beowoulf LaTower Thanks for providing feedback on the latest mobile app update.
Kind regards,
BrianL
NETGEAR Community Team
