beowoulf
May 18, 2016Aspirant
ios and ready cloud
Just did ios software update for ready cloud and app does not work. It immediately closes when opened and if you go to running apps and open it again it will close completely. This happens on new and ...
- May 30, 2016
New software update in App Store available. Bug fixed, works great now. Thank you Netgear.
BrianL2
May 30, 2016NETGEAR Employee Retired
Hi frisoco,
Can you update the ReadyCLOUD mobile app on your iOS devices (version 1.5.8) and see if you'll be able to access your ReadyNAS files?
beowoulf LaTower Thanks for providing feedback on the latest mobile app update.
Kind regards,
BrianL
NETGEAR Community Team
frisoco
May 30, 2016Aspirant
Hello Brian,
I updated yesterday, and things are working like a sunshine again.
thanks a LOT!
thumbs up for netgear!
kind regards,
frisoco
- BrianL2May 31, 2016NETGEAR Employee Retired
Hi frisoco,
We appreciate your feedback and for letting us know that the recent ReadyCLOUD app update for iOS has helped resolve your issue If your issue is now resolved. We look forward to hearing from you more and be a helpful resource in the future!
Kind regards,
BrianL
NETGEAR Community Team- Kberna1376Jun 06, 2016Apprentice
Ios app shows my 104 as "Connected (Readycloud)"
my 204 shows "Connected (VPN)
What is the meaning? Should both read VPN, or Readycloud, or does it matter?
- StephenBJun 07, 2016Guru - Experienced User
You get better performance (and Netgear's costs are less) when you connect locally to the NAS and avoid the cloud servers. So the ReadyCloud apps and PC software try a local connection first, and then fail over to VPN if that doesn't connect.
The NAS itself needs to maintain a lightweight connection to the ReadyCloud server (through the VPN) even if your apps aren't using the cloud servers at the moment.
So this is normal behavior.
