ivanmalek
Nov 28, 2016Aspirant
move finished project to archive
Hi, new user here, so I hope my question is not stupid. I'm using my NAS both to back-up my data and keep the HDD of my workstation clean, so I imagined, I would have a "work" folder on my workst...
Nov 28, 2016Guru - Experienced User
How are you synchronizing the local folder and the NAS work folder?
What ReadyNAS do you have (RN202?), and what firmware is it running?
- ivanmalekNov 28, 2016Aspirant
Hi,
I'm running firmware version 6.6.0, i synchronized the folder using the ReadyCloud app, by pressing the "backup pc folder" button in the bottom left corner.
- StephenBNov 28, 2016Guru - Experienced User
ivanmalek wrote:
Hi,
thx. I'll move the thread to the ReadyCloud folder then. I don't use ReadyCloud myself, hopefully someone else will chime in on your sync question.
