ivanmalek
Nov 28, 2016Aspirant
move finished project to archive
Hi, new user here, so I hope my question is not stupid. I'm using my NAS both to back-up my data and keep the HDD of my workstation clean, so I imagined, I would have a "work" folder on my workst...
Nov 28, 2016Guru - Experienced User
How are you synchronizing the local folder and the NAS work folder?
What ReadyNAS do you have (RN202?), and what firmware is it running?
ivanmalek
Hi,
I'm running firmware version 6.6.0, i synchronized the folder using the ReadyCloud app, by pressing the "backup pc folder" button in the bottom left corner.
- StephenBNov 28, 2016Guru - Experienced User
ivanmalek wrote:
Hi,
thx. I'll move the thread to the ReadyCloud folder then. I don't use ReadyCloud myself, hopefully someone else will chime in on your sync question.
