mstay
Jul 18, 2016Aspirant
MyNETGEAR account, ReadyCLOUD, and ReadyNAS Duo v2
I have a ReadyNAS Duo v2 (RND2000v2) that I have been using successfully for quite some time with ReadyNAS Remote and an older version of ReadyCLOUD. I received an email from Netgear stating that I ...
- Jul 20, 2016
Hi mstay,
Welcome to the community!
There's no need for that. Just log in using your old ReadyNAS remote ID and the new password (that you've entered during the migration).
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Jul 20, 2016NETGEAR Employee Retired
Hi mstay,
Hope this helps!
Kind regards,
BrianL
- mstayJul 22, 2016Aspirant
Thank you for the advice. That worked well and I can now once again access my shares through ReadyNAS Remote.
- az_ukJul 29, 2016Aspirant
Hi all,
I have a similar issue.
I have two Nas drives - the newer of the two I can access through Ready Cloud. I am unable to access the older one. I tried entering the new details but it only shows the new drive. Please help!!!
Let me know if you need any more information from me.
- StephenBJul 30, 2016Guru - Experienced User
You could of course just type the model information and firmware, and ignore the model dropdown :smileyhappy:
ReadyCloud is only for ReadyNAS that run 6.5.x firmware. It won't work with older 6.x firmware, and it won't work with 4.x or 5.x either.
