mstay
Jul 18, 2016Aspirant
MyNETGEAR account, ReadyCLOUD, and ReadyNAS Duo v2
I have a ReadyNAS Duo v2 (RND2000v2) that I have been using successfully for quite some time with ReadyNAS Remote and an older version of ReadyCLOUD. I received an email from Netgear stating that I ...
- Jul 20, 2016
Hi mstay,
Welcome to the community!
There's no need for that. Just log in using your old ReadyNAS remote ID and the new password (that you've entered during the migration).
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
mstay
Jul 22, 2016Aspirant
Thank you for the advice. That worked well and I can now once again access my shares through ReadyNAS Remote.
az_uk
Jul 29, 2016Aspirant
Hi all,
I have a similar issue.
I have two Nas drives - the newer of the two I can access through Ready Cloud. I am unable to access the older one. I tried entering the new details but it only shows the new drive. Please help!!!
Let me know if you need any more information from me.
- StephenBJul 30, 2016Guru - Experienced User
You could of course just type the model information and firmware, and ignore the model dropdown :smileyhappy:
ReadyCloud is only for ReadyNAS that run 6.5.x firmware. It won't work with older 6.x firmware, and it won't work with 4.x or 5.x either.
- az_ukAug 21, 2016Aspirant
Hey all,
I was hoping someone could help. Ideally, I would like to find out the external IP address of a ReadyNas Duo v2 running RAIDiator 5.3.11. How can I do this? I used to use Ready Nas remote which would display the external IP address but that doesnt seem to work on the Ready Nas Duo v2.
Ultimately, I am using AllWay Sync to sync between this Nas Drive (that is kept at another location), with the one at my place that is a ReadyNas 202 running 6.5.1.
Any help please!
