Retired_Member
May 18, 2016no access NAS on ReadyCloud after 6.5.0 update
I'm getting the same problem. Have migrated my account however now says ReadyNAS is offline, which it isn't.
jdou
May 18, 2016Aspirant
I have the same problem here. Once I updated firmware, I cannot access solders through readycloud. Can only do so as an Administrator, so basically I can only access them from home. When I treid to create account link, it didn't recognize password and asked me to chnage it. Once I changed it, then I got an error message!
- Peter_noviceMay 19, 2016Aspirant
same issue here ...
- i tried the recover from sources.zip - no success
It shows first the message "6001010106" and since the sources.zip installation it also shows "Device communication failed".
- mdgm-ntgrMay 19, 2016NETGEAR Employee Retired
Peter_novice wrote:
same issue here ...
Have you tried rebooting and if that does not resolve it an OS Re-install.
That config backup just overwrites one config file with one change.
