Retired_Member
May 18, 2016no access NAS on ReadyCloud after 6.5.0 update
I'm getting the same problem. Have migrated my account however now says ReadyNAS is offline, which it isn't.
Peter_novice
May 19, 2016Aspirant
same issue here ...
- i tried the recover from sources.zip - no success
It shows first the message "6001010106" and since the sources.zip installation it also shows "Device communication failed".
mdgm-ntgr
May 19, 2016NETGEAR Employee Retired
Peter_novice wrote:
same issue here ...
Have you tried rebooting and if that does not resolve it an OS Re-install.
That config backup just overwrites one config file with one change.
