Retired_Member
May 18, 2016no access NAS on ReadyCloud after 6.5.0 update
I'm getting the same problem. Have migrated my account however now says ReadyNAS is offline, which it isn't.
Peter_novice
May 19, 2016Aspirant
Hi thanks for the fast reply.
I rebooted several times. No success.
Can you please provide me instructions how to reinstall the OS.
mdgm-ntgr
May 20, 2016NETGEAR Employee Retired
- Peter_noviceMay 22, 2016Aspirant
Hi
thank you for your instructions. I've re-installed the OS. Still the same error message (6001010106), when i connect by readycloud. After clicking ok I tried to browse the NAS. Then it says "No Volume on Disk".
I also tried to remove the readycloud user. In the admin page it is shown without an icon and without an e-mail address but with name and typ. However, when I want to delete the cloud user, then a dialog box is shown that I should do it via Readycloud ... and here I do not see where to delete the respective cloud user.
Frustrating ... I'm spending now hours with this ... maybe it's cheaper to get another box that works.
... finally I'v deleted the readycloud NAS connection and all accounts ....
... re-connected everything ... now it works.
However, I'm not at all happy with this "upgrade" scenario I had to go through ... such things should not be tested by end users.
- BrianL2May 23, 2016NETGEAR Employee Retired
Hi Peter_novice,
Thanks for the feedback. We apologize for the inconvenience and if you have gone through some problems after the update. I hope things will go well from here.
Kind regards,
BrianL
NETGEAR Community Team
