Retired_Member
May 18, 2016no access NAS on ReadyCloud after 6.5.0 update
I'm getting the same problem. Have migrated my account however now says ReadyNAS is offline, which it isn't.
mdgm-ntgr
May 20, 2016NETGEAR Employee Retired
Peter_novice
May 22, 2016Aspirant
Hi
thank you for your instructions. I've re-installed the OS. Still the same error message (6001010106), when i connect by readycloud. After clicking ok I tried to browse the NAS. Then it says "No Volume on Disk".
I also tried to remove the readycloud user. In the admin page it is shown without an icon and without an e-mail address but with name and typ. However, when I want to delete the cloud user, then a dialog box is shown that I should do it via Readycloud ... and here I do not see where to delete the respective cloud user.
Frustrating ... I'm spending now hours with this ... maybe it's cheaper to get another box that works.
- Peter_noviceMay 22, 2016Aspirant
... finally I'v deleted the readycloud NAS connection and all accounts ....
... re-connected everything ... now it works.
However, I'm not at all happy with this "upgrade" scenario I had to go through ... such things should not be tested by end users.
- BrianL2May 23, 2016NETGEAR Employee Retired
Hi Peter_novice,
Thanks for the feedback. We apologize for the inconvenience and if you have gone through some problems after the update. I hope things will go well from here.
Kind regards,
BrianL
NETGEAR Community Team
