Retired_Member
May 18, 2016no access NAS on ReadyCloud after 6.5.0 update
I'm getting the same problem. Have migrated my account however now says ReadyNAS is offline, which it isn't.
JavierCortez
Jul 05, 2016Aspirant
I resolved this by doing the following:
- Login to your local ReadyNas admin
- Click on cloud
- Click "Leave" under ReadyCLOUD
- You will get prompted (I think) - Select Yes/OK if so.
- Once the page reloads - Turn on the ReadyCLOUD setting
- You will/should get a notification once you log in that a previous user has been renamed due to conflicts. I think this is where the bug originates.
- After you login, try to access via the online portal.
Hope it helps!
vtxrider
Jul 05, 2016Tutor
Perhaps you misunderstood the issue I am having, it is the iPhone app that will not access my shares while on cellular, (although it shows the NAS online) the web portal on both my phone and computer have no problem. It's just that the app would be a better user experience than the browser on the phone.
