thetedium
Oct 09, 2016Star
no registered devices
There are no satisfactory answers thus far in the community about solving no registered devices for a readynas 10400 readycloud is activated on the nas port 6200 is open on the router firewall a...
- Dec 01, 2016
All fixed.
Thanks to Jie and Framer.................I now have access to my files on mobile.
All worked after Jie accessed my comp via team viewer.
kohdee
Oct 19, 2016NETGEAR Expert
If ReadyCLOUD does not see your device registered, then somehow ReadyCLOUD was registered on your device but not on the server, which is not common, unless you have firewall services blocking connections. Review your firewall logs to confirm what kind of behavior the ReadyNAS is making when you are attempting to connect to the internet with ReadyCLOUD. You can also try removing your device from ReadyCLOUD and trying to re-join ReadyCLOUD with your SSO login.
thetedium
Oct 20, 2016Star
i press the button and it says discovery on on the nas. It finds it temporarily in the manage tab
nas is allowed through the firewall
When I turned remote diagnostics on for the netgear tech, could you see the NAS?
- thetediumNov 04, 2016Star
alrightey, remote diagnostics has been on for two weeks. Any update?
- StephenBNov 04, 2016Guru - Experienced User
Who are you asking? Is there a ticket number, or a request from a specific Netgear person to turn the diagnostics on?
- thetediumNov 30, 2016Star
Mdgm asked me to turn it back on. That was three weeks ago
- StephenBNov 30, 2016Guru - Experienced User
In general, it is good to follow up via PMs if you don't hear back after putting the system into diagnostic modes. Netgear support (and mods) are multi-tasking, and somethings things do get accidently dropped.
