mrQQ
Jun 11, 2016Apprentice
OS6, 6.5.0, ReadyCLOUD - Services Offline
Hello, I have RNDU4000 with OS6, running 6.5.0. I wanted to setup ReadyCLOUD, but it says at the top Internet Available, Services Offline. There is a question mark, but I cannot click it, so ...
wolfie111
Dec 08, 2016Guide
I'm having a similar problem, local admin, cloud tab shows Internet green check, services red x when u turn on ReadyCloud switch. I tried to leave and rejoin with my netgear account login credentials and the behavior repeated, no services. I also changed the email address for the netgear account so it was different from the administration account, nothing changed. can see available apps on that tab, see all shares via ReadyCloud on other clients, but I cannot setup local users! Please help.
- mrQQDec 11, 2016Apprentice
I think in my case it was because I had http/https services disabled.
- FramerVDec 12, 2016NETGEAR Employee Retired
wolfie111,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
