Jevalent15
Dec 23, 2016Aspirant
Overcoming Crippling Syncing Limitations
Using ReadyNas 214 with OS 6.2 Firmware 6.6.2. My remote computer is a MacPro with OS 10.11.6 I want to define the specific location of the sync folder on my computer as well as on the ReadyNAS. ...
FramerV
Dec 25, 2016NETGEAR Employee Retired
Hi Jevalent15,
As far as I remember that is a limitation on the ReadyNAS sync. When I get a chance I will try it our in our office, I will try to give you feedback.
- Jevalent15Dec 31, 2016Aspirant
That's some limitation!
That and not being able to access any drive but my boot drive makes the ReadyNAS utterly useless for syncing.
- StephenBDec 31, 2016Guru - Experienced User
It sounds like your goal is backup - is that correct?
If so, running a continuous (or scheduled) backup program on the PC with the destination on a NAS share might work out better.
(I agree that ReadyCloud sync is very limited).
- SandsharkDec 31, 2016Sensei
I don't use ReadyCloud sync, but have you tried creating a symboilic link to the other drives on your boot drive? In some software, that gets around problems accessing drives (more often for mapped drives, but it could work here, too).
