Jevalent15
Dec 23, 2016Aspirant
Overcoming Crippling Syncing Limitations
Using ReadyNas 214 with OS 6.2 Firmware 6.6.2. My remote computer is a MacPro with OS 10.11.6 I want to define the specific location of the sync folder on my computer as well as on the ReadyNAS. ...
Jevalent15
Dec 31, 2016Aspirant
That's some limitation!
That and not being able to access any drive but my boot drive makes the ReadyNAS utterly useless for syncing.
Dec 31, 2016Guru - Experienced User
It sounds like your goal is backup - is that correct?
If so, running a continuous (or scheduled) backup program on the PC with the destination on a NAS share might work out better.
(I agree that ReadyCloud sync is very limited).
