rklunder
Mar 26, 2020Aspirant
Pioneer Pro upgraded to OS6 cant connect to readycloud.
I have a pioneer pro upgraded to OS6 (currently 6.10.3) whose serial number matches eth0 causing issues connecting to ReadyCloud. Is there a solution I can implement to get the serial number correcte...
- Mar 26, 2020
Hi rklunder,
The fix has been applied. Please check if it has the correct serial number now.
