relains's avatar
relains
Tutor
Aug 04, 2016
Annoying ALT + TAB behavior
Hi, I have a suggestion that to change some functionality in the app, beacause now even when it resides in the tray when I ALT + TAB it shows on the list of active applications. I frequently use thi...
  • BrianL2's avatar
    Aug 04, 2016
    Hi relains,
    Your idea to improve the quality and functionality of the app is very much appreciated, and we thank you for sharing your interest in this. I also found this behavior a bit odd and hopefully we can make improvements on how the app be properly viewed on PCs. If I were you, I will post another thread at the Idea Exchange board so our development team can review this request.
    Kind regards,
    BrianL
    NETGEAR Community Team
ProSupport for Business
