confeder8
Jun 16, 2021Follower
ReadyCloud Desktop Application shows all in Capital Letters and does not Connect
I am using ReadyNAS 212 since last 2 years without any issues. After Re-Loading of OS (Windows7, duly updated with all Service Packs), I am unable to login in the RN212 from Desktop Application. th...
JohnCM_S
Jun 19, 2021NETGEAR Employee Retired
Hi confeder8,
It could be an issue with Java. You can try updating the Java on your computer to the latest version then remove the previous afterward.
You can also try installing this patch to the Win 7 .NET framework. Some users have reported that this fixed that issue on their Windows 7 computer.
You may also check this thread for reference
