GeorgeCRD
Dec 04, 2022Tutor
ReadyCLOUD gone after April 4th, 2023
I received this email from Netgear on 12/04/2022: "We wanted to let you know that NETGEAR is discontinuing support for the ReadyCLOUD feature on your NETGEAR router on April 4th, 2023. The ReadyCL...
nsne
Dec 08, 2022Virtuoso
This is admittedly not the ideal solution but I'll mention it just as a potential alternative.
I'm using an Asus AX89X router with the new .388 firmware branch that supports WireGuard. It's incredible. When I'm outside the house, it's giving me almost seamless high-speed access to my entire local network, my ReadyNAS included, on all my devices. So if you think the cost–benefit is there, it might be something to consider. The AX89X, like a lot of new Asus routers, has 10Gbps LAN ports and a multi-Gig WAN port, so you get more out of >1Gbps NAS and ISP connections if you have happen to have them.
