Retired_Member
Oct 02, 2015ReadyCLOUD Login screwed up
I've been running my 314 fine for months but I have somehow screwed up my Login settings for ReadyCloud. I can still access my Admin page OK but the Cloud On/Off button is Off and will not toggle to ...
- Oct 04, 2015
Sorry about the late reply. but somehow my Forum Logins had changed as well. Thank you for the LInk, after about 1 hour of trying various combinations of email & password I managed to Login to ReadyCLOUD but got a popup saying no Registered Devices ! so I was able to get onto my Admin page and via the Cloud Settings dialogue box enter my found details and toggle the ReadyCLOUD button to ON. Launched the ReadyCLOUD Windows App and entered my found details there so back to normal ? possibly. Thank you once again for your help. Still a mystery why it said no registered devices!
JennC
Oct 03, 2015NETGEAR Employee Retired
Hello ispy1,
Try using Forget your ID or password option at https://remote.readynas.com/. Once you are able to login to this URL, you should be able to see your userID, it is case sensitive so please take note of it as you have to type it the same exact way it is registered.
ispy968
Oct 04, 2015Aspirant
