Daktari
Feb 16, 2016Guide
ReadyCLOUD not connecting
I have a readycloud installed on an iMac runing MacOS 10.11.3. New install of ReadyCloud for MacOS v2 FM ver 6.4.2 I suddenly have a problem with connecting. The following situation applies: ...
- Feb 17, 2016
I disabled IPv6 on the ethernet adapter for the RN202, this solved the problem.
Thanks, hope it helps someone else.
BrianL2
Mar 10, 2016NETGEAR Employee Retired
Hi Dom-Juan,
Are you still experiencing slow access to your files via ReadyCLOUD? Have you tried the web portal page or mobile app instead?
Kind regards,
BrianL
NETGEAR Community Team
Dom-Juan
Jul 12, 2016Tutor
Just to close this out: ReadyCloud continued to be low in performance. In the end I switched to Owncloud , and I have a very neat personal cloud , running over Softether VPN . It's very userfriendly, and the integration with my two ReadyNas'es syncing each other gives me all I need and more.
Cheers, Juan.
