klausn
Mar 31, 2018Tutor
ReadyCloud v2.0.1(today updated) but seems it doesn't work
Hi anyone, Do you update to the latest version ReadyCloud v2.0.1 (iPhone 7+), but seems it doesn't work. Just start the app and nothing happens, does anyone have the same issue? Can't logout or...
- Retired_MemberApr 26, 2018
Hello all
I uploaded patch files(fix 409 conflict issue) to ReadyCLOUD,please download them at
for X86 device
https://readycloud.netgear.com/client/dllink.html#t=002jm6o5pm6/readynasos_6.9.3%2B3_amd64.deb
for ARM device
https://readycloud.netgear.com/client/dllink.html#t=07g704laopx/readynasos_6.9.3%2B3_armel.deb
walshlink
Apr 14, 2018Luminary
I am on iOS 11.4 (beta), App v2.0.1, and OS 6.9.3, and am getting “Network error occurred”. I was getting this error, then got everything to work once I reinstalled the OS on my NAS, but then the error came back.
greispe
Apr 14, 2018Tutor
There is clearly a problem with the latest release of Readycloud on the latest iOS release. I have the same issue on my iPhone and several iPads.
I tried it on my older iPad mini with iOS 9 and ReadyCloud 2.0.0 and it works fine, so it might not be a problem with the ReadyNAS O/S.
- walshlinkApr 14, 2018LuminaryIt appears if my iOS device is connected to the LAN through WiFi, I get the error. Once I shut down WiFi and go through my cellular data connection, the iOS ReadyCloud app connect to my NAS. When I turned on WiFi again, shutdown my cellular data connection, the error comes back.
NETGEAR, the problem clearly lies with the iOS ReadyCLOUD app not being able to use the local LAN when there is one available (unless that is by design and can only get to the NAS through the Internet).- walshlinkApr 14, 2018LuminaryStill have cellular data shut off and now I can connect to NAS using ReadyCLOUD app using WiFi...definitely some bugs in the app.
- walshlinkApr 14, 2018LuminaryTried to upload photos using ReadyCLOUD app and it immediately crashes. App is completely usuable at this point.
- greispeApr 14, 2018Tutor
I confirmed the exact same behavior as Walshlink. The app is definitely flakey. Works on cell connection, doesn't work Local LAN.
