klausn
Mar 31, 2018Tutor
ReadyCloud v2.0.1(today updated) but seems it doesn't work
Hi anyone, Do you update to the latest version ReadyCloud v2.0.1 (iPhone 7+), but seems it doesn't work. Just start the app and nothing happens, does anyone have the same issue? Can't logout or...
- Retired_MemberApr 27, 2018
Hello all
I uploaded patch files(fix 409 conflict issue) to ReadyCLOUD,please download them at
for X86 device
https://readycloud.netgear.com/client/dllink.html#t=002jm6o5pm6/readynasos_6.9.3%2B3_amd64.deb
for ARM device
https://readycloud.netgear.com/client/dllink.html#t=07g704laopx/readynasos_6.9.3%2B3_armel.deb
walshlink
Apr 15, 2018Luminary
Tried to upload photos using ReadyCLOUD app and it immediately crashes. App is completely usuable at this point.
walshlink
Using cellular data (and disabling WiFi) seems to work just fine.
- walshlinkApr 15, 2018Luminary
- klausnApr 16, 2018Tutor
Hi all,
Do you have the same problem as me with ReadyCloud (v2.0.1) on a iPhone (iOS11.3)?
I have a small update:
Netgear provided me today an higher version (v2.0.2) for testing it. It seems that this version also isn't working!
(Even I created a new directory! It's not working)
Netgear is on the moment busy to find the root cause.
When they have found it they will solve it with a new relase!
So keep in touche, I will update this Topic in here when it is solved!
Klaus
- klausnApr 21, 2018Tutor
Hi all,
Netgear provides me a patch update for RedayCloud NAS OS6.9.3.
It seems it works fine, but I need to check my destination directory for more than >9000 pictures.
This coast a lot of time to verify it.... and I need to scedule it...
Netgear will update this topic soon!
Klaus
