klausn
Mar 31, 2018Tutor
ReadyCloud v2.0.1(today updated) but seems it doesn't work
Hi anyone, Do you update to the latest version ReadyCloud v2.0.1 (iPhone 7+), but seems it doesn't work. Just start the app and nothing happens, does anyone have the same issue? Can't logout or...
- Retired_MemberApr 27, 2018
Hello all
I uploaded patch files(fix 409 conflict issue) to ReadyCLOUD,please download them at
for X86 device
https://readycloud.netgear.com/client/dllink.html#t=002jm6o5pm6/readynasos_6.9.3%2B3_amd64.deb
for ARM device
https://readycloud.netgear.com/client/dllink.html#t=07g704laopx/readynasos_6.9.3%2B3_armel.deb
walshlink
Apr 15, 2018Luminary
Using cellular data (and disabling WiFi) seems to work just fine.
walshlink
- klausnApr 16, 2018Tutor
Hi all,
Do you have the same problem as me with ReadyCloud (v2.0.1) on a iPhone (iOS11.3)?
I have a small update:
Netgear provided me today an higher version (v2.0.2) for testing it. It seems that this version also isn't working!
(Even I created a new directory! It's not working)
Netgear is on the moment busy to find the root cause.
When they have found it they will solve it with a new relase!
So keep in touche, I will update this Topic in here when it is solved!
Klaus
- klausnApr 21, 2018Tutor
Hi all,
Netgear provides me a patch update for RedayCloud NAS OS6.9.3.
It seems it works fine, but I need to check my destination directory for more than >9000 pictures.
This coast a lot of time to verify it.... and I need to scedule it...
Netgear will update this topic soon!
Klaus
- greispeApr 25, 2018Tutor
Any update on the patch for ReadyCloud on iOS?
