klausn
Mar 31, 2018Tutor
ReadyCloud v2.0.1(today updated) but seems it doesn't work
Hi anyone, Do you update to the latest version ReadyCloud v2.0.1 (iPhone 7+), but seems it doesn't work. Just start the app and nothing happens, does anyone have the same issue? Can't logout or...
- Retired_MemberApr 26, 2018
Hello all
I uploaded patch files(fix 409 conflict issue) to ReadyCLOUD,please download them at
for X86 device
https://readycloud.netgear.com/client/dllink.html#t=002jm6o5pm6/readynasos_6.9.3%2B3_amd64.deb
for ARM device
https://readycloud.netgear.com/client/dllink.html#t=07g704laopx/readynasos_6.9.3%2B3_armel.deb
klausn
Apr 27, 2018Tutor
Hi greispe,
1 ReadyCloud, which version do you use? ( I'm using Version 2.0.1(2040) on my mobile device)
2 Did you remove the app. from your phone and reinstalled it? if not please remove it.
(Remarks: before remove, first sign out! Wait untill you are logged off, then remove the app.
Then reinstall the app. and sign in again)
If this not helps? Please be kind and see topic: "Network error on readycloud app as well." for more details.
Klaus
greispe
Apr 27, 2018Tutor
Klaus:
Ok good suggestion. I uninstalled the app from my iPhone and reinstalled it (I have been using Version 2.0.1 (2040)). Still get the same error:
Error
Network error occurred
So far I have logged out, reinstalled the app, rebooted the phone and the ReadyNAS and I still get the error message. It works fine when I am remote to my LAN.
What did you do to get it working?
Peter
