klausn
Mar 31, 2018Tutor
ReadyCloud v2.0.1(today updated) but seems it doesn't work
Hi anyone, Do you update to the latest version ReadyCloud v2.0.1 (iPhone 7+), but seems it doesn't work. Just start the app and nothing happens, does anyone have the same issue? Can't logout or...
- Retired_MemberApr 26, 2018
Hello all
I uploaded patch files(fix 409 conflict issue) to ReadyCLOUD,please download them at
for X86 device
https://readycloud.netgear.com/client/dllink.html#t=002jm6o5pm6/readynasos_6.9.3%2B3_amd64.deb
for ARM device
https://readycloud.netgear.com/client/dllink.html#t=07g704laopx/readynasos_6.9.3%2B3_armel.deb
klausn
May 02, 2018Tutor
Hi,
I'm sorry for all how still have an other Network error issue!
I'm not Netgear expert and I can't give you the solution.
I gave already a suggestion and the next suggestion is:
"Create an new Topic for Netgear or search how others it solved"
In this topic I was started from the beginning, was an other issue and that is solved!
Klaus
greispe
May 03, 2018Tutor
Klaus:
Yes I understand you have your problem fixed. However, there are others that still don't have the problem fixed. So the patch works for you. I want to leave this thread open, as Netgear still needs to solve this problem.
Klaus: Can you just summarize your current configuration for your system where the Netgear patch worked. That would me further diagnose this issue. Thank you!
Netgear please continue to research this issue. As you can see there are several of us here that have the same issue.
