appierro
Jan 14, 2018Apprentice
Readnas cannot connect to readycloud
ReadNas cannot connect to Readycloud. Something is preventing. Disks are good. Local Admin account is set up with same email as MyNetgear account.
- Jan 25, 2018
Netgear engineers connected to my NAS via ReadNAS Diagnostic mode and removed a corrupt Config file. Once they removed the config file, I was able to connect to ReadyCLOUD. Thanks,
appierro
Feb 12, 2018Apprentice
@rickr1 I believe it's a pretty quick fix and hopefully StephenB can reach out to you as well. I believe he's working with vverma01 to get his resolved.
Feb 12, 2018Guru - Experienced User
As far as ReadyCloud goes, I focus on whether the NAS has the right network connection to reach the internet. I can't really go further than that - I access my own NAS remotely using VPN, not ReadyCloud. So once it's clear that the issue isn't the network itself, I need to leave it to the Netgear team.
- rickr1Feb 13, 2018Aspirant
Thanks Stephen. My NASes all have full network access to the Internet and are all configured in exectly the same way with the exception of this problem of it not being able to register with readycloud.
Actually, I may turn this around and provided I can swap my drives around between the NASes maybe I acn demote this one to a backup role and promote one of my other ones to be the primary role. But realistiacally I should not be having this problem at all. The ALL my NASes are running at the same OS releases and I upgrade all of them at the same time.
Netgear should publish more information on this issue if they cannot automate a patch.
Cheers,
Rick
- mdgm-ntgrFeb 13, 2018NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
