Spurs1984
Jun 18, 2016Aspirant
Readnas Remote Stopped working after conversion to single sign on MyNetGear account
Netgear have forced a change from the readycloud sign on to a MyNetGear single sign on. The readnas remote software now will no longer sign in as the user name has changed and it does not recognise ...
JennC
Jun 21, 2016NETGEAR Employee Retired
Hello Spurs1984,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Spurs1984Jun 21, 2016Aspirant
Hi
The original account has been migrated to the new Netgear account and does not work. In the end i created a new account and have successfully used that to access Readynas remote. The secret is not to migrate your acccount if you use the older Readynas remote software
- JennCJun 21, 2016NETGEAR Employee Retired
Hello Spurs1984,
If you are not using ReadyCloud and a ReadyNAS OS6 unit then it is better if you do not upgrade your account so you won't get confused but as advised by Netgear, all should be migrated to SSO. The SSO migration is for the users to use just one account to access registration of his/her Netgear products as well as signing in to ReadyCloud. As for ReadyNAS Remote, you should be using the old account name and use the password of the myNetgear account.
For example, your ReadyNAS Remote and ReadyCloud account is xyz and then after migration it is now using email address that is associated with it which xyz@email.com, upon migration it asked you for a password to setup with the new account. After this migration, you should still be able to use the old xyz account name with ReadyNAS Remote and ReadyNAS Replicate, but the password you should use with it is the password of your new account xzy@email.com.
- JennCJun 24, 2016NETGEAR Employee Retired
Hello Spurs1984,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
