RustyShakleford
Aug 30, 2019Tutor
Ready Cloud PRJNAME?
Why has the Ready Cloud Desktop App suddenly changed? Now I can't connect using it and it has a strange "PRJNAME Login" on it. It seems to have come about after an update of the app, but I am not sur...
RustyShakleford
Aug 31, 2019Tutor
JohnCM_S wrote:Hi RustyShakleford,
Welcome to the Community!
This issue could be related to the Java version installed on your desktop computer. Have you tried updating the Java on the computer and removing the previous versions afterward?
If you have any security software installed on the computer, you may try disabling that and then try reinstalling the ReadyCLOUD app.
I uninstalled the ReadyCloud app, unisnstalled Java, installed the latest version of Java and the ReadyCloud app. No change. The only security software present is Windows Defender, which has not changed.
Sandshark
Sep 01, 2019Sensei
Try installing this patch to the Win 7 .NET framework: https://support.microsoft.com/en-us/help/3154518/support-for-tls-system-default-versions-included-in-the-net-framework.
- RustyShaklefordSep 03, 2019Tutor
Sandshark wrote:Try installing this patch to the Win 7 .NET framework: https://support.microsoft.com/en-us/help/3154518/support-for-tls-system-default-versions-included-in-the-net-framework.
Wow, that actually worked! Thank you!
