GaGirrl
Dec 01, 2017Aspirant
Ready Cloud Set up/Add Users
I have a ReadyNAS 104 FW version 6.8 that has ReadyCloud enabled. I logged into ReadyCloud.netgear.com with the account I used to enable ReadyCloud (it shows "signed in" in the ReadyNAS admin page un...
GaGirrl
Dec 14, 2017Aspirant
Hi Marc,
I already see the the settings you indicated that the Internet is available Services Available with the green checkmark but I don't see the option like the example below to add shares on the ReadyCloud option.
However, we do see the shares on the network and they are accessible so I'm not sure why ReadyNAS and ReadyCLOUD see two different things.
JohnCM_S
Dec 19, 2017NETGEAR Employee Retired
Hi GaGirrl,
Just to clarify, are you trying to create a share folder through Readycloud or are you trying to invite users through Readycloud? Can you provide to me a screenshot of what you see on the Readycloud portal?
JohnCM_S
NETGEAR Community Team
- StephenBDec 19, 2017Guru - Experienced User
Normally you'd create shares using the normal web ui, and then invite ReadyCloud users to access those shares with ReadyCloud.
