MWThewsey
Nov 27, 2017Initiate
ReadyCLOUD - Reinitialising backup folder
Hi I have been using my ReadyNAS to backup specific folders from my desktop. The ReadyNAS is at a different address so I have been using the ReadyCLOUD app. I initialised the backup of a folder (...
MWThewsey
Nov 30, 2017Initiate
Hi
Thanks for replying.
I do not have the option to start/stop the backup, so I cant try that one.
I do have the option to sync to PC, however this then makes a 2-way transfer directory, which is fine.
However there is a problem. When I start the sync, it created a new directory on my C drive and starts to download all the files.
Is there any way to re locate where it syncs the files too. I need the files to sync onto another drive.
Matthew
Marc_V
Dec 06, 2017NETGEAR Employee Retired
Hi MWThewsey
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
