leahcimd1
Jan 15, 2015Apprentice
ReadyCloud & ReadyNAS duo v2
Hi, How do I add my two ReadyNAS duo v2's to ReadyCloud? When I run the ReadyCloud Discovery Page and press the backup button on them they are not discovered.
Nhellie
Jan 16, 2015Virtuoso
You will have to use ReadyNAS remote client since the Duo does not support ReadyCloud. Check this thread, it might give you some information about legacy products and remote:
viewtopic.php?f=23&t=79513
- kokoschOct 10, 2015Aspirant
Now what can I do?
ReadyNas Remote seems to be not supported by indows 10.ReadyCloude is not supported by my ReadyNas Dou V2.
I need help- EskenderNGOct 14, 2015NETGEAR Employee Retired
Hello,
There is a ReadyNAS Remote Beta App with WIndows 10 support.
Bye,
Eskender
- kokoschOct 20, 2015Aspirant
Thank You
