nildame
Nov 05, 2017Aspirant
ReadyCloud Account Gone Missing
We use this box for basic file sharing in a home office. A Readycloud account was set up in order for box to initially work in February 2016. Because of basic use, migration (ready cloud to mynetge...
Nov 09, 2017Guru - Experienced User
nildame wrote:
Today, we decided to back up ReadyNAS files into a USB external drive and realized we can't do without the Readycloud
That is absolutely not the case.
You can log into the NAS web ui, and create a backup job there that will write to a USB external drive. No need for ReadyCloud.
There is a guide here: https://kb.netgear.com/29654/How-do-I-back-up-data-from-my-ReadyNAS-OS-6-system-to-a-USB-disk
I recommend ignoring the advice there to use EXT formatting - I think it's much better to use NTFS. A backup you can't read on your PCs isn't very useful.
- nildameNov 10, 2017Aspirant
Thanks Stephen for your comment. Yes, that's the back up instruction I was trying to do but could not get past step 1 as I don't know how to get the System-Overview to come up on my desktop. I was under the impression that that screen comes up after logging into ReadyCloud. If there is another way to get that screen up, will you let me know?
Thanks again,
Nilda
- JohnCM_SNov 11, 2017NETGEAR Employee Retired
Hi nildame,
If you know the IP address of your ReadyNAS, you may go to that page by accessing https://<ReadyNAS IP address>, where the <ReadyNAS IP address> is the IP address of your ReadyNAS.
If you do not know the IP address of your ReadyNAS, you can install and run RAIDar on a computer that is connected to the same LAN with the NAS and check its IP address. You can download the RAIDar installer here.
JohnCM_S
NETGEAR Community Team- JohnCM_SNov 14, 2017NETGEAR Employee Retired
Hi nildame,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,JohnCM_S
