Ioannis
Jun 09, 2016Aspirant
ReadyCloud Account
Hallo.
I'm new in the community and also new to the Nas Storage system and I need your help.
I've created me Netgear account and registered the product.
I;m trying to connenct to the ReadyCLOUD page using my Netgear account.
The Nas 104 is discovered, but when i'm trying to access it i get a message that says Divice Communication Error the ReadyCloud has lost communication with my storage system. When I clik the "Try Again" button i'm getting on a loop.
I suppose that I have do something wrong.
I also believe that i have not created a ReadyCloud account, since i'm login with the Netgear credentials.
Please help
- Retired_MemberJun 09, 2016
Did you check the online documentation?
- Retired_Member
- BrianL2NETGEAR Employee Retired
Hi loannis,
Welcome to the community!
Aside from the article posted by jak0lantash, you can check this article that will help you create your ReadyCLOUD account using your existing MyNETGEAR account.
If you have time, I suggest you to read the MyNETGEAR SSO FAQ.
Kind regards,
BrianL
NETGEAR Community Team
- IoannisAspirant
Your answers were very usefull.
I managed to solve the problem and now the system works perfectly.
Thanks a lot.
- Apr 16, 2020Retired_Member
