mikecusumano
Dec 15, 2016Aspirant
ReadyCLOUD Android
Hi, At my wits end with this. Myself and another employee can connect to the ReadyNAS with the ReadyCLOUD app when using our Android phone wifi and on the local netork. We cannot connect if we ar...
- Dec 16, 2016
OK, I resolved this myself.
Apparantly the X next to Services is bad so I went down that route to TS I Found this thread and edited the lnconfiguration.xml with WinSCP and rebooted. All good!
Anyone else looking at this thread, you will need to enable SSH and give your admin account SSH rights under the user account on the dashboard.
You can close this now. Thanks.
Dec 16, 2016Guru - Experienced User
Are you seeing anything at readycloud.netgear.com?
mikecusumano
Dec 16, 2016Aspirant
yes, all the folders and files are accesible. the desktop client works as well remotely. i have seen a few posts with people expressing the same issues with a mobile client and none have any kind of resolve.
