themuhammadshk
Apr 22, 2022Aspirant
ReadyCloud app macos is not installing
Hi, i am having an issue in installing the readycloud app on my macos. i have already enabled setting for downloading third party unidentified developers apps but still cant install it on my mac run...
Marc_V
Apr 22, 2022NETGEAR Employee Retired
Welcome to the Community!
It seems that your settings allows you to download and install pkgs but the error points out to a failed install. Were you able to try redownloading the package? where did you get it?
FYI
https://support.apple.com/en-us/HT202491
You can also try downloading this file
matthieu4
Sep 10, 2022Aspirant
J'ai le même problème, possibilité d'avoir le lien ?
