tripz0011's avatar
tripz0011
ReadyCLOUD Backup
So I am doing backups of the NAS to ftp.
however whenever I run it I get errors all the time.
It looks like the backup tries to copy over the Netgear created hidden direction and it fails on it.. How do I get the backup to skip a hidden folder or bypass its hidden default folders.
Backup Start Time: Wed May 16 2018 16:03:39
Backup Finish Time: Wed May 16 2018 16:03:56
Backup Status: Fail: Failure during copy.
Failed to create remote directory backups/NASWPB/.readydrop! Quote command returned error
.readydrop!  is a hidden folder the the Readycloud GUI cannot see but it tries to copy it. Sick of seeing errors and failures on the backup.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi @tripz001
    If I understood it correctly, you are doing a backup through FTP through the backup job. Are you backing up from ReadyNAS to FTP Server or a remote ReadyNAS?
    What firmware are you running?
    Regards
  • Anonymous's avatar
    Anonymous
    I cannot reproduce this issue,here is my backup log
    Backup Job Name: wdew
    Backup Job Type: Incremental
    Protocol: ftp
    Backup Source: [NJ-JDAI-T480-uacdump]/
    Backup Destination: [remote:ftp]/ftp://10.40.0.145/Documents
    Backup Start Time: Tue May 29 2018 4:57:58
    Backup Finish Time: Tue May 29 2018 4:58:05
    Backup Status: Success
    Copy (D) .readydrop
    Copy (F) trigger snapshot upgrade.txt
    Copy (F) mount VMDk.txt
    what remote FTP server are you using?can you check permission setting on remote device?
ProSupport for Business
