TimOverfield
Feb 28, 2017Aspirant
ReadyCLOUD Desktop Client shows device offline
I have been using a ReadyNAS 104 with 12 TB of disks since 2013 which has always been reliable when accessed over my local network. However I now need to access it remotely and have tried using Read...
- Mar 16, 2017
Problem now fixed by Daniel in Netgear Support as follows;
Solution part 1: Removing User Conflicts.
Cloud users and local users cannot share the same name or email address.
We edited your local user and removed the email address, which was used on as the name on your cloud account.
Solution Part 2: Restarting the Service.
Last year (firmware 6.5.0), we upgraded ReadyCloud. You had upgraded your account correctly, but we could see in the Cloud tab of your ReadyNAS that it was still linked to the old username, rather than the account's email address.
There was a few things we could do here, but as you were not using the readycloud home folders, the quickest solution was to click the Leave button and to re-enter your details.ReadyCloud now operating on W7 and W10 machines.
Retired_Member
Mar 03, 2017Hello TimOverfield
can you please check if Leaf network interface of your Windows has obtained IP address from server?you can go to Network and Sharing Center>Change Adapter Setting>Leaf Networks Adapter>Details,correct IP should be 5.*.*.*,did you install any firewall application on your Windows?
