OF
Dec 19, 2016Aspirant
ReadyCloud: Device is offline
When I log onto ReadyCloud it says my device is offline and to check internet connectivity and that it is on. We had a powercut over the weekend and so a few systems rebooted, including the ReadyNas ...
- Jan 06, 2017
There were some entries missing from a config file as this system was updated from very old firmware. I added those missing lines in and it has resolved the problem.
JennC
Dec 19, 2016NETGEAR Employee Retired
Hello OF,
When you login to ReadyCloud, click Home instead, this should load all the ReadyNAS units that registered to ReadyCloud with your account and ReadyNAS units that invited you to have access.
- OFDec 20, 2016Aspirant
Hi,
I have been clicking on Home. This is where it is saying my device is offline. Thank you.
- JennCDec 20, 2016NETGEAR Employee Retired
Hello OF,
When you do this, is the computer connected to same network where the NAS is and is it wireless or wired to the network?
Please also check in the admin page > Cloud > ReadyCloud if it is turned ON and if the Internet and Services have green check mark.
- OFJan 03, 2017Aspirant
Hi,
The computer is connected to the same network wirelessly. ReadyCloud is also ON and the green check mark is displaying.
Thank you,
Olivia
