OF
Dec 19, 2016Aspirant
ReadyCloud: Device is offline
When I log onto ReadyCloud it says my device is offline and to check internet connectivity and that it is on. We had a powercut over the weekend and so a few systems rebooted, including the ReadyNas ...
- Jan 06, 2017
There were some entries missing from a config file as this system was updated from very old firmware. I added those missing lines in and it has resolved the problem.
Retired_Member
Dec 20, 2016Hello OF
Can you please send NAS system log? I want to take a look ReadyCLOUD log to determine the issue.
OF
Jan 03, 2017Aspirant
Hello,
I have emailed the logs. Thank you for taking a look.
- mdgm-ntgrJan 03, 2017NETGEAR Employee Retired
Thanks for the logs. I have sent you a PM.
- mdgm-ntgrJan 06, 2017NETGEAR Employee Retired
- bimmerx2Jan 06, 2017Aspirant
Can you share the fix. I have the same situation - Readycloud is turned on, green checkmarks, settings look good, device always says "offline" regardless of where I'm connected. It was working good until the firmware upgrade a few months ago, then it died.
- FramerVJan 08, 2017NETGEAR Employee Retired
Hi bimmerx2,
Welcome to the community.
Kindly try updating to the latest firmware; it has a fix for DNS lookup which affects ReadyCloud activity.
ReadyNAS OS 6 Software Version 6.6.1
If that does not resolve it please send in your logs. See How do I send all logs to ReadyNAS Community moderators?Regards,
